erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
Well, after working four months on my first boat, a 1973 Sea Ray SRV220, replacing transom, stringers, floor and everything but the engine, I finally gave up without ever getting it into the water. Too much work left to get it done before next year, and I just don't have the patience remaining.
Since I have a good job, I'm fortunate enough to have a little cash for spending, and I found a great deal on another boat almost the same type, a 1983 SR-210CC. The guy I bought it from said the motor was cracked - milky oil. I figured ok, I have the motor from the other boat. I didn't know it would be a ton of trouble to switch them, so I bought the boat for $500. It was well worth that even if the motor was gone.
I changed the oil, saw no additional water getting in, and just about cheered. I took the boat to the lake, actually got to drive it for 15 minutes (a friend drove it too, and we worked on the trim pump the rest of the time - turned out to have low oil). It was GREAT!
Then, on the way home from the lake, the trailer started to sway back and forth hard. It spun around, lost the boat, and almost rolled my truck. $1200 in towing fees later, I'm having the truck repaired so it's driveable.
I don't have a ton of cash left. So, I was hoping that the boat wouldn't take much to repair.... it didn't look bad, just some chips and scratches on the hull bottom, a trashed sterndrive (I have the spare from the other boat) and the hull/cap joint separated on one side for about 6 feet. Plus the cap is split on the same side in one place.. the fiberglass I can fix. But...
I took some pics tonight... found out that the motor is full of milky oil again, so I need a new engine. The motor also shifted off its mounts(!) when the boat went off the trailer... it pulled out the lag bolts that it sits on and shifted to starboard. The mounts are ok, I just need new bolts. But, it also snapped off the ears on the inner side of the transom plate. Again, I have a spare from the other boat, the difference being that the newer boat has power steering and the old boat didn't. I'll have to make that work somehow.
Here's a pic of the sterndrive... the bell housing took most of the force, but when I rotate the prop I hear something clicking inside, like a gear is snapped or something. I'll replace the entire drive with the one from my other boat I guess.
Also, here's a link to the rest of the pics.
http://www.greendragon.org/oops/
I'll keep you guys updated and plead for help and moral support as I work on this. I'm going to order a long block from either basicpower or rapido marine soon. I already have a new set of electric brakes for the trailer, too.
erik
erik
