froggy1150
Master Chief Petty Officer
- Joined
- Nov 3, 2017
- 898
Do your fillets and all your tabbing at the same time. Your bubble roller will make a good radius and the hard to reach stuff just use finger
One of the most time consuming aspects of a project such as this was getting the transom area clean and removing any old gelcoat but it is so critical for the reconstruction phase. I could not wait to get past the grinding!Got old engine mounts cut out yesterday, and started on removing transom wood which is proving to be tough stuff. Where there is no rot it is well glued and taking a lot of work to bust it loose.
Yes I find if you try to remove it a sheet at a time it goes better than trying to pry parts of two sheets at a time off. Will put some more time in today. I'm dealing with I/O hole patch job also. Hope removing plywood doesn't affect outer skin over the old hole.Looks like you’re getting after it. Getting the transom wood out is a bear. I used a circular saw set at 1/4” and made small 6” squares all over the transom. Then was able to chisel them out one by one. small steps will get you there.
When I got that close to skin I used a multi tool with flat toothed scraper. Then rolled into a sander of choice with 180, 220,380 grit. Sander made fast work of it. Scuffs up skin for good adhesion later.A little tardy on the pics. One pic shows the front end where I need to clean off the glued wood stuck to the top of the fiberglass stringers, tidy up my cleanup for peanut butter down the sides, and for cloth overlap of the floor. Will have to put a couple cross members in the middle where the sheets of decking meet in the middle. At the stern need to clean Up old engine mount base. Continue the middle stringer to the back and tie all three stringers into the new transom. Will leave a little gap on the bottom of the stringers meeting the transom for drainage to the bilge. Which it never had before which is very strange. Meanwhile have to givertomorrow on the transom cleanup. .
Got some time in today and pretty much down to skin other than the thin stuff left. Thanks for the tip to get rid of it. I will get the rest of transom cleaned up tomorrow.When I got that close to skin I used a multi tool with flat toothed scraper. Then rolled into a sander of choice with 180, 220,380 grit. Sander made fast work of it. Scuffs up skin for good adhesion later.
Yes I'm pretty happy about how it went and what I got done. Finish the one corner, then make sure floor and transom edges are smooth and ready for glassing, clean off top of stringers, and can probably get after putting it back together.Looks real good. When I was this far, I just hosed out the debris and also used bleach to kill bs in small pockets. Yours looks darn clean. Prior to glassing wipe it down with acetone.
Cheers!
