New prop
Jon1229
hi,
I’m in the market for a new prop could someone just tell me what the dimensions are I know it’s easy but I’m new to it so I don’t wanna screw it up. 0A1916x 19p. Also, aluminum or stainless better?
ThomW
That part number is for a 14.5 by 19 pitch prop. Are you looking to keep it the same? Change your RPM's at all?
As far as aluminum versus stainless, that all depends on your motor, boat, use, and wallet.
What boat are you running this prop on? What size motor? And what kind of boating are you doing?
Both types have their pros and cons. All depends on what you are trying to accomplish with your new prop.
Sea Rider
If wanting to replace current prop going for same new one, it's probably a bad idea, as there's no wot data mentioned in your post assume previous prop was not tached at all. Won't know if prop is reving as currently loaded inside safe min-max wot rpm range factory stated to know if best suited for your boating application.
Happy Boating
