I have rebuilt damn near everything except foot and powerhead, still having an issue with running consistently. Last week I pulled the intake and reed plate and checked everything there. I found the vent hole on the reed plate was completely stopped up and cleaned that up, i flipped the reeds over so that they have no play in them. That helped it run consistent, it no longer surges up and down, however it still doesn't rev up like it should. The original cylinder head had a repaired spark plug thread, some kind of insert, so I replaced the cylinder head monday, didn't make any difference. I did however notice that as the fuel got lower in the tank, the engine revved higher and almost ran as it's supposed to. So my question is this, Is it possible that by replacing the the filter inside the tank with an inline filter, could i have restricted the fuel flow and therefore have the carb starving for fuel? On the tank side of the filter I can see air bubbles int he line, the carbn side doesn't have any, does this matter? I'm baffled!!
Original post
http://forums.iboats.com/showthread.php?t=504486&highlight=ducktwin
Original post
