New Questions
keelbolts
Good evening gents,
A few questions for you MFG guys. I have a '60 Oxford Deluxe hull that's missing almost everything.
How is the plywood floor attached to the aluminum stringers & keelson?
What are the dimensions on the aluminum channel that sits athwartships on top of the stringers & fwd section of plywood floor about where the front seats go?
Do the fasteners for the stringers pass thru wood strips attached to the outside of the hull?
Thanks.
*EdC*
Re: New Questions
keelbolts
Several members have Oxfords. I'm sure one of them will chime in to help you out. If you cruise this forum you'll see a lot of pics and things. Also check out the restoration section
SteveMFG_Oxford
Re: New Questions
My '61 has a 1/2" plywood floor that appears to be screwed to the metal stringers with s/s screws with finish washers. My guess is that they are just #10 self-tapping metal screws. I personally have not removed the plywood deck as it is still pretty solid. I believe this to be the second floor in this boat.
Due to a large repair I found on the bottom that was probably "healed" from the inside and a few other "tells", plus the 51 year age I'm pretty confident this is correct.
