New Sea-Pro CC owner with questions
skippingtrout
After years of looking and procrastination I finally bought a boat, a 2002 190 Sea Pro CC with a 115 four-stroke Merc. I had been looking at boats that were much more $$ and when I found this one I had to buy it. I had never heard of the brand before and did my research here on iboats. After reading many posts I was confident this would be a good boat. The plant closer has me a bit nervous about resale value. Fortunatly I have some room, I paid $3000 less than NADA suggested.
After two days of intense cleaning I know the boat much better now. The front anchor bin drain was clogged with gravel and funk. After much fuss I finally got it somewhat clean. Any suggestion on how to service the drain? I almost think it has a screen or something is that true?
There are some rust stains inside the plastic live wells, any suggestions on how to clean 'em up would be greatly appreciated.
Also I noticed several spider cracks near the bin lids and corners, people tell me that's normal and nothing to worry about. Are they right?
I was sad that the boat was too tall to fit in my garage, I bought a cover but it fits poorly. Any suggestion on how best to store this boat outside. I'm a crazy neat freak and need her in constant showroom shape.
I'm taking her out Sunday I'll have pics and a first impressions to share.
Thanks,
Skippingtrout
Re: New Sea-Pro CC owner with questions
As far as I know there is no screen on the drain. On mine it is connected separately to a drain hole on the transom. Sometimes during construction they leave little bits of fiberglass and adhesive behind that end up in these drains.
I use a product called Never Dull for upkeep on my Sea Pro. It is great for just about any surface and stain. On deeper rust stains I use a little Muratic acid... it doesn?t hurt the fiberglass or plastic if rinsed off shortly after application.
Spider cracks are a normal occurrence especially on boats kept outdoors in the heat and sun. They should not hurt anything except aesthetics.
Hope this helps...
skippingtrout
Thanks for the reply and info.
First trip today. Went 9 miles north out of Port Sheldon and then 9 miles south to Holland and into lake Macatawa. Wave were around 2-3 on the way out and settled to about 2 footers on the way home. The boat ran well and all seemed to go smooth.
A lot of water drained out when I got home, we had several large waves come in the back, I'm thinking the water got in that way.
I wish I could get it up on plane quicker. I know the kids will want me to pull them around on the tube soon. Has anyone put a fin or trim tabs on a Sea Pro 18 CC?
Thanks,
skippingtrout
mspm47
i have a 98 190CC and really like it. it has a 150 Yammer 2stroke that has no problem coming out of the water. I had a fin on a bowrider i used to have and i could not tell it made any difference. I could be wrong.
We keep ours outside and i have a double cover deal. I have a center console cover (that is vented) that i wrap bungee cords around the bottom. Then i have a full coverage cover that i attached to lines to the trailer. When stored, i take out the drain plug and prop open all the storage spaces so they can get some air.
Monitor the water you are taking on as a day of boating goes on. Make sure your bilge is directly wired to your battery. I know someone that was taking on water from the livewell grate on the hull.
May all your water be wet
WeeBee Crabby
Charleston SC
Gmonkey
SkippingTrout,
Congradulations on your Sea Pro. I have a 2004 190. I agree that it is a great boat for the money. It is a good compromise of a compact size and able to handle rough seas well. I have never been splashed or sprayed in 3 yrs of ownership with 30 days of saltwater fishing mixed in.
I have some spider cracks too around the front live well. I don't think it's a big deal. Once they form, the don't get any worse.
I have a 115 4stroke Yamaha. It is a little sluggish to get going especially with a heavy load. Two full livewells in the rear are the biggest factor. I installed two large trolling motor batteries in the back so that also makes it worse. The boat is now a little tail heavy, so I installed a set of Smart Tabs and that made a big difference. I recomend them. There is alot of chatter about these on this site.
I'm also big on keeping it super clean. I have to because it's also a family cruising boat. I like Bar Keepers Friend for all rust and other stubborn stains. It has Muratic acid in it.
Let's see some pictures! Mine is in the Sea Pro picture thread.
Clay
