baconbiscut
- Joined
- Jul 11, 2006
- 367
I have an early 70s 17' Dixie Trihull with the Mercruiser 140. I recently installed a new SEI drive because the old drive had a very worn clutch dog in it. The new drive has a 1.94 ratio which I believe is a slightly taller gear than the older factory drive. Prior to the replacement I was seeing about 4500 rpm and 37 mph trimmed out in smooth water with just me and a full tank of fuel running a 3 blade 19 pitch prop. Now I'm topping out at 4200 and 37 mph. I believe the rpm range for my engine is 42-4600. I'm considering going to a 17 pitch four blade to get to the upper end of the rpm range with a light load. My old drive had a hydrofoil on it but I'm not keen on drilling holes in my new drive just yet. I've heard that a 4 blade provides more lift. Does this seem like a good choice? Also if it helps, I rarely exceed 3500rpm. When I'm running I usually keep it between 3-3500 but I spend a lot of time trolling and cruising a long at 1500.
