new sparkplug
JESSIELSMALL
what is the correct gap for a new spark plug on a 1991 200hp johnson. also is ngk a good sparkplug for this engine, or should i change to different type for better performance
Dhadley
Re: new sparkplug
It's best to stay with Champions on that motor. Especially if you're using something other than the recommended (fresh) 87 octane. The motor was designed to run Champions and other brands tend to have different burn properties. If it were mine I'd use the QL77JC4's. Since you didn't say how the motor is being used we'll assume it's standard recreational use and the top rpm is between 5500 to 6000. Depending on what you're doing those plugs can be gapped anywhere from .030 to .040".
