jiggineyes
- Joined
- Mar 12, 2009
- 14
Just got a new starter less then 2 weeks ago. Had some fuel issues which with your guys help i was able to rebuild the carbs and fuel pump effortlessly. Thank you
. Anyways, was making my final adjustments on the idle when I I went to start it for the last time and all of a sudden my starter goes out. Relay just clicking. Same as when the starter went bad 2 weeks ago.
The day i got the starter I put it in and nothing. I brought it back and turns out the manufacturer had a paper gasket between body and ends, disrupting ground. They removed the gasket and it was good to go. Put it on and has worked good since.
My question is, is there something that could have caused this or do you think its just something went wrong with the starter? The relay is new as well and all connections were good when i put it on. Could there be a short causing it? Is there a way to check before I get the starter replaced so it wont happen again? Thanks!
