- Joined
- Jul 23, 2011
- 53,081
Wife's audi has a bunch of weather messages too.
I love 10 speed transmissions. Had it on my 2018 F-150 and have it on my 2024 GMC 2500. Both are the smoothest shifting transmissions I have ever owned and perfect for towing, although they never go above 8th gear while towing. Coupled with adaptive cruise control, you never have to deal with turning off cruise even when the transmission is shifting under load.10 spd transmissions
Love my ten speed in my 2025 Chevy 2500. Pulls like freight train when loaded. Smooth as can be everyday driving.I love 10 speed transmissions. Had it on my 2018 F-150 and have it on my 2024 GMC 2500. Both are the smoothest shifting transmissions I have ever owned and perfect for towing, although they never go above 8th gear while towing. Coupled with adaptive cruise control, you never have to deal with turning off cruise even when the transmission is shifting under load.
Lou, have you ever driven a car with a 10 speed especially towing?
absolutely.There's some good here, but some of it, is so irritating, I don't think I can live with it. I'll take auto braking and adaptive cruise control but the rest please. We are all grown-ups now.
More than that, here are things forced on us I really don't care for:
CVTs
all aluminum and plastic engines
direct injection
plastic oil pans
wet belt designs
front and rear fascias retained by 30 cheap little plastic fasteners
full roof sunroofs that creak and leak
most of this is to reduce weight some is to increase efficiency but not ONE DANG bit of concern for repair costs. Why do you think your insurance is so much more expensive?
You have a back up camera, great till it breaks then your car won't pass inspection till you fix it for $2 grand
You brake a tail light on a Ford F-150 just check the price on that ($1700?)
and politicians crow about "affordability"
No I haven’t but test drove a Bronco with it. Just not used to that much shifting I guess, seeing as how what I’ve driven for many years are Chrysler automatics (4 speed 42RE very old school, & 545RFE, the last Chrysler designed auto before they went to the ZF 8 speed).I love 10 speed transmissions. Had it on my 2018 F-150 and have it on my 2024 GMC 2500. Both are the smoothest shifting transmissions I have ever owned and perfect for towing, although they never go above 8th gear while towing. Coupled with adaptive cruise control, you never have to deal with turning off cruise even when the transmission is shifting under load.
That’s one reason why I kept the old 98 ZJ Grand Cherokee. Simple vehicle no screens no nanny devices it does have the long lived AMC/Chrysler 4.0 six and the manual NV 242 transfer case with 2wd, 4 high, 4 high full time & 4 low. Best t case ever put in a Jeep. It does have 4 channel abs which was better than some vehicles of that era. Drivetrain has over 180,000 on it now.I also run vehicles for about 15 years/300,000 miles or more. the screens in my 2014 GMC are both going belly up. the fix is to buy new screens. however if that happens, the motor and trans will go stand-alone ECM. the problematic 6L80E will get rebuilt for the 4th time or replaced with a 6-speed manual at which point the iffy T-case with the electric shift will be replaced with an Atlas unit. the infotainment unit will get replaced with something, and the truck gauges will get replaced with AutoMeter.
then again, all the exterior weatherstripping, plastic light housings and plastic trim on the truck is deteriorating at an alarming rate. Today's vehicles are just NOT designed to go more than 8 years or 100,000 miles like the vehicles were just 15 years ago.
With the old 98 it still has the original differentials (owned since new) @ 183,000 miles. Always used full syn 75/140 gear oil maybe that helped. The 4.0 six models had the Dana 30 up front & Dans 35 in the rear, the 96-98 V8s had the aluminum Dana 44 which was more trouble prone. My 07 with the 5.7 Hemi has been very good, no major mechanical problems at all, just a few electrical issues. Both need some rust repair at this point. If I could find a clean 07-10 5.7 with no rust & low miles sure I’d buy it!Had a couple of those myself. Prone to rear diff problems (staying locked up or whining) though?
One of my customers is a fan of the later Hemi engine'd Jeeps, collects and runs them, fixes some up and sells them on, I do quite a lot of work for him on them. He's an IT guy and wrote some diagnostic software for Jeep / Chrysler. He says a common problem is when someone tries to code a new key using a not totally compatible cheap Chinese key programer, it can sometimes cause the immobiliser to lock out all keys with not much chance of anyone being able to fix that except himself. A lot of those he buys are none-runners due to immobiliser problems lol. But he lost money on the last one he bought at auction, 5.7 Hemi (he prefers the bigger Hemi) with the wasted spark cross over ignition wires, when he bought it someone had disconnected all the wires from the engine, just needed me to connect it all back up so the engine would run. As soon as it started the engine was knocking and misfiring, seems he bought one with what might be a dropped valve, not quite the bargain he was expecting it to be.
You hardly feel the shifts in a 10 speed. BTW, when you drove that bronco, it skips gears 2 and 4 unless you were in sport or trailer mode. F-150s do the same.No I haven’t but test drove a Bronco with it. Just not used to that much shifting I guess, seeing as how what I’ve driven for many years are Chrysler automatics (4 speed 42RE very old school, & 545RFE, the last Chrysler designed auto before they went to the ZF 8 speed).
