NEW TIRES--HELP
OLDSPUD
I NEED TO REPLACE THE TIRES ON MY TRUCK, THIS IS THE TRUCK THAT I PULL MY BOAT WITH. IT IS A '03 CHEV 2500 HD. I am running ten-ply tires, last time the tire dude recommended them because of the weight of my boat 6,400 lbs., dry.<br /><br />These are a little expensive to replace, and was considering dropping to an 8-ply tire, Toyo something AT or a Cooper something AT. I can save over $200 to $250 clams if I drop down. Any help from you guys will help.<br /><br />Spud
TwoBallScrewBall
Re: NEW TIRES--HELP
Multi ply tires are better suited for puncture resistance than load handling (as far as I know). Any load-rated tire that would come on that truck stock will be more than adequate. Up in Maine where I hunt they are big on the 6-ply and thicker tires becuase of the 100's of miles of dirt road up there, someone is always poking a pointy rock through a tire up there.
KM2
Re: NEW TIRES--HELP
I have never paid attention to the ply, just load rating. I have had good luck with cooper tires and think they are a great tire for the money. Look good, plus made in the USA.
Bob_VT
Re: NEW TIRES--HELP
I would suggest staying with the proper load rating for the 3/4 ton....any brand will work as long as they are rated for the 3/4 ton truck.<br /><br />Do not put yourself in jeopardy by putting the wrong load rating tires on.<br /><br />Bob
LubeDude
Re: NEW TIRES--HELP
It really doesnt matter how much you boat wieghs, unless you are hauling it in the back of your truck. Which I doubt!! Tonge weight is all that matters. The tires designed for your truck are fine. The only thing I might think abought would be side wall play, which would be stiffer with an 8 ply. If I towed accross county all the time, I might go for the more expensive tire, if you are just going a few miles to the ramp, your stock tires would be fine.
dolluper
Re: NEW TIRES--HELP
Copper tires have a softter compound making them stick better but less wear capibility the more the ply the better the durability for rough terrain Goodyear has some real good ones
Re: NEW TIRES--HELP
There's No Sense in buying tires that are Weight Rated Higher than your Truck..........<br />I Bet your "Tire Dude" was working on a commission.............<br /><br />I've run Bridgestones, Dunlops,+ Others....<br />There's a set of Generals out on the Battlewagon right now, LT235/85R/16E...........<br /><br />That was the tire(size/rated) that Ford put on the truck,+ They rated it at 8800lbs......<br /><br />As noted above, it's the Rating, not the plys that Matter.................<br />It sounds like you're in the market for "E" rated tires..............
How Do you get That Much Boat in an 8' Bed..???... :D <br /><br /><br />Good Luck,...........And, Keep Your Money............. ;)
