matt167
- Joined
- Sep 27, 2012
- 4,469
I install trailer tires professionally as part of my day job and not through a mcdiscount tire shop. so I can give some sound, accurate advice.
The best tire that you can buy is Goodyear Endurance radial. The Goodyear Marathon is a tire to avoid.
Michellin rates their LT truck tires for trailer service, if your size is available
A good runner up is a Carslile Radial Trail, or any other radial trailer tire that has a wider casing. Cheap junk tires will have beads that nearly touch each other when deflated.
Only buy a bias ply if you must. They are on the low end of the cost spectrum and a handful of use case scenario's where they are better ( not on a boat trailer ).. If you end up spending anything more than $40 more each per tire, give or take, you are getting ripped off.. Keep in mind tire prices are going up daily at this point
