Hi all,
I'm the proud owner of a brand new TLDI 50hp; I've got about 2 hours left in the break-in period and I couldn't be happier with the motor so far. I'm running it on a home built 17' cc skiff and getting performance numbers almost identical to this test with the stock 13 pitch prop: http://www.trailerboats.com/output.cfm?id=2259109
My dealer sent me home with a gallon of Yamalube 2M... They mostly deal in 4 strokes in the Tohatsu line and don't carry the Tohatsu / Nissan branded oils in gallons. After I'm done with this gallon of Yamalube, I'd like to switch to a full synthetic. I'll stay with the factory recommendations, and the Tohatsu/Nissan oil is hard to find in gallons here, and also hard to find on the internet. I'm thinking XD100 or maybe the Pennzoil.
My question is, how to switch without unnecessarily mixing the oils? I can't exactly run the tank dry as I'm sure the warning system will scream at me well before the tank is actually near empty. I've heard that I should avoid mixing the oils.... If this isn't a problem then my question is answered. If it is....
Maybe I'm being anal, but Evinrude's literature on the E-Tec and XD100 has me thinking, specfically that the E-Tec can be programmed to pump less oil if the owner uses only XD100. Not that my motor will use less, but if the oil is that much better....
Thoughts?
Thanks,
Matt
Thoughts?
Thanks,
Matt
