hello all, a few weeks ago i bought a 1971 sea star, never seen it in the water been setting for 2 years, so got it home , got it running ( still needing alil motor work) , steering was stuck, so got that working, so heres whats left, ( other than the motor) need to repair the floor, its not to bad just weak in spots, so should i replace it or just cover the biggest part of the weak spots? the next ? is i was workin on the wiring of the lights today and it has a pull switch, now is the green and red lights on front and the one rear clear , suppose to be on a circut that u can run just run the green and red light and a different circut for the rear, or is it when u turn them on they all are on? also it has alil push button, which i thought was a horn button but after looking at the wiring it went to the lights?
hmmm not sure about that one, also on the side there are little J hooks like 6 per side and i noticed that they are kinda loose so u think i sould just take them out and fiberglass over them or silicone around them?and just one more ?
there is no bulge pumps in it, but torward the drain there is 2 hole one on either side, of the drain , on the inside of the boat on the floor, im guessing thats where a bulge pump would go but do u place the bulge pump under the floor? or right in between the 2 holes? sorry this is so long, il probably have more ?S since im a newbie
thanks for all the help
Jeremy
ps this boat and trailer has a clear title for both, the trailer is in very good shape, boat is in ok to good shape, picked it up for $400.00 so i really cant complain
Jeremy
