New to boats and this my surprise you but i have a motor question
southernrebel1
Ok i am buying a 20'' sun tracker and of the avalible motors which one should i get and why?
60 ELPT FourStroke EFI BigFoot
75 ELPT FourStroke
or the
75 ELPT OptiMax
Silvertip
Re: New to boats and this my surprise you but i have a motor question
On a pontoon I like a four stroke so either the 60 or 75 is fine with a nod toward the 75 if you will be pulling water toys. I prefer a two stroke on a go fast boat.
The Rooster
Ensign
+1^^^ The difference in fuel efficiency between 60-75 is small.
lncoop
If that barge is only twenty inches long I think all of those motors will be too big. Sorry, couldn't resist!:p I agree with the guys. Biggest you can afford. By the way, given your username I assume you're south of MD line. Can you dial that in a little? I ask because we're working on a get together and would be honored if you were able to join us.
southernrebel1
So the 4 stroke 75 would be my best best?
Being that it is only 1k more over the 60 bigfoot i would be more than happy to get it if i am gonna be able to really tell the dif.
How much more power/Mph can i expect from the 75 over the bigfoot?
The Rooster
Ensign
Hard to say "Rebel", but I'd think 3-4 mph more. Not sure about the 75-4-stroke, but the 75 Optimax is a larger family of engines w/ a good bit more torque for when you have a larger load aboard. Thats where you'll notice the biggest difference. Good luck !!!
southernrebel1
So does anyone have the merc 75 4 stoke if so how does it perform?
southernrebel1
Also why won't this forum let me edit my post?
Nevermind it was the ipad giving me probs.
southernrebel1
Anyone else have any input?
I am leaning to the 4stroke 75 but i want to make sure tis the best option from people who know what they are talking about like the fellas who have posted already.
Does anyone have a similar setup to the 20ft toon with either of these motors?
P.S
Sorry if i seem in a hurry but we are going friday to spec it out and have it ordered. I hate we are going to have to order it but the only ones they have instock all have carpet and we are going with the coastal package with the rubberized nonslip floor covering.
lncoop
I don't have any specs for you rebel, but generally speaking the four stroke will give you better fuel economy and run a little quieter but will come with a higher maintenance burden, while the Opti will give you better hole shot and maybe a little more speed (can't say for sure on the speed) than the four stroke but burn more gas. I'd say the main factor in your decision should be how you plan to use it. If you'll mainly be cruising and trolling you'll probably be better of with the four stroke; quieter and cleaner and happier at lower RPMs for extended periods but still enough guts to get you off the water quickly if necessary. On the other hand, if you envision a lot of water sports and a desire to get to a spot quick you'd probably be happier with the Opti. In the end it's a question of happier, not happy, because you'll be happy with either motor. Which one will you be happier with? That's ultimately up to you.
southernrebel1
Thanx for the info guys I went with the 75hp 4 stroke.
lncoop
Cool. Let us know how everything turns out.
