Re: New to iBoats: Starcraft Restoration Project
I just took another look at the picture you provideed. Once you have the wheel off the chrome trim ring just under the steering wheel will come off. Under that chrome trim ring is where the bolts are located to remove the drum assembly.
Ok...that is what I like to hear. I am hoping to address the wheel this weekend.
To date:
* All hardware removed, itemized, and stored. Most of it being original will return to the boat...polished nicely.
*I have applied two coats of primer to the topside, filled in holes and deep scratches. I will be finishing the last sanding in preparation for paint.
* Took some poly resin & glass matt to the stern deck area to reinforce for raised fishing seat.
Next:
* Buying deck ply and marine carpet (more poly resin)
* Sizing aft bench seating area and will be making a new bench seat.
* Looking for two forward seats, probably will have them swivel
* Carb kit and new impeller for Johnson 40
* In the hunt for a used trolling motor 40+ thrust. Not sure if I will go with a bow or transom mount.
Thanks for all your input.
