new to me 2002 kawi ultra 130 wont run how to test fuel pump???
neversinksmith
hey guys I just picked up this pwc and its acting like its not getting fuel. sat for 5 yrs w out being used. drained old gas and she fires on fluid but I don't think the fuel pump is working .pulled the fuel lines off injectors and fuel does not squirt out lines when cranking. is there some way I can test it or did i? thanks
WaterDR
Post this question on Greenhulk forums and you will get immediate help.
zdeyonker
Check the fuel pump fuse to begin with, then you can try applying voltage directly to the fuel pump after pulling the connector out of the harness.
