deerslayer1985
- Joined
- Apr 7, 2011
- 2
I just bought a 9.9 hp ted williams from my brother in law. It is the model number 217/58621-1. I was wondering if there was some place where you could download a manual for this engine? I need to clean out the carb and don't know how to completely disassemble it. Its a touch different then the ones I worked on. Also what type of fuel tank, and gas line should I be using? I just hooked up a 6 gallon auxillary tank with a line and pump bulb. It runs for awhile and will kick off every once in awhile? It acts like its not getting enough fuel. Sometimes it runs for 20-30 minutes, sometime 2-3 minutes. I'm running 50-1 mixture in it right now. What should the mixture be for the gas? What oil should I use in the lower part? I seen a little screw on by the carb is that an air/fuel adjustment? I messed with it a little bit, but it didn't seem to do much. Does anyone know how to tune that? Thanks for any help.
