So, I picked up this 16' 1975 Wellcraft the other day from a young guy who was tired of trying to figure it out. He told me he had it on the water in April, but it ran rough. He has replaced pretty much everything in the ignition system except the distributor itself. He said he replaced the points, plugs, wires, cap, rotor, alternator and coil. Now it will not start at all. He said he took it to a mechanic that he knows and was told that the distributor needs to be replaced. I pulled the cap off and the insides of the distributor look new and it has no play in it. A mechanic that I spoke to said that he did not think it was the distributor unless it was just really sloppy and had a lot of play in it. I tend to agree with him, as long as it spins and has spark to send out to the plugs, it should be ok
I am completely new to inboards, so I have been reading the posts to try to figure it out. I read through the sticky's and did some preliminary troubleshooting and I do not seem to have anything coming out of the coil. I am not sure that the P/O has not done some messing around with the wiring. One thing that he did was bypass the mechanical fuel pump and rigged up an electric one, which he had connected to the + terminal on the coil. The mechanic I spoke to said this could cause interference in the firing.
I have attached some pics of the boat along with the wiring around the coil/distributor area and I hope that some of you can spot what might be wrong with the wiring, if there is anything wrong. I also found the attached wiring diagram in a post and was hoping maybe someone can tell me if it is the correct one for this engine.
The serial number from the plate on the engine is 4187035. I am assuming that it is the original engine for the boat, which would make it a 1975 model.
Also, if someone can maybe tell me the model of the boat, I would appreciate it. If not, I will post separately in the Wellcraft forum.
Thanks in advance for your assistance.View attachment 140 wiring.pdf
