New to me boat with VP 5.7GS
Galvez83
Hey folks, i will like some input as to what to go over in a new to me VP 5.7GS engine to help it last longer. So far i have done a compression check on all 8 cyls and came back with 175-180 across the board. From what i can gather the boat 2001 Wellcraft 2600 Martinique has been sitting sometime unused. The clock read 200 hrs. Unsure if accurate or not. I have replaced the oil sender switch, oil sensor, temp switch, temp sensor. The alarm has a steady beep before starting that goes away after engine is running. Will also address the bad belts. New pump and impeller are coming due to pump leak. I will also look at the risers and manifolds since i am unsure about their history. I have also replaced the cap and rotor of the prestolite because they where in poor conditions. On start up the engine is not very happy for about a couple of seconds and then it stays running fine. What would be recomendations to make this grumpy engine happy again?
Lou C
And spark plugs
Also esp if used in brackish or salt water; exhaust elbows. Esp if there are any rust stains in the joint between the manifold & elbow…
Donald0039
I would send out the carb to be rebuilt by a professional. Many just throw on a carb rebuilt kit but don't get all the passages clean. The professional will use an ultrasonic cleaner.
But first check you choke.
Lou C
They now sell ultrasonic cleaners big enough to hold a Quadrajet or Holley 4bbl. I’m gonna get one!
Galvez83
Yes, the carb is not looking the best to say the least. Working to get my hands on a 1409. Currently has a 2 barrel Holley and cranky indeed on startup. Oil psi states 25-30 psi which did not sit right even with new sensors and senders. I hooked a gauge to it and its reading 45 idle, something else to gaze at...the gauges.
There should be an adapter on the intake that can be removed to bolt on a 4-barrel.
There are only 2 gaskets needed to go through a Holley 2300 2-barrel. Most of the crud will have blocked the metering plate passages. If you do a whole teardown there are only about 6 parts on the carb
Lou C
Agreed a Holley 2bbl is about as simple as it gets. For a $40 rebuild kit it could be as good as new, as long as it’s not corroded inside.
