new to me evinrude with issues
skinny1965
I recieved a 40 hp evinrude on friday model 40673B serial C503404
I had it fire and run off fuel dumped in the carb so that part as good prospects.
the wire harness was cut off right at the cowl but I did get the box with regulator and shift box
I have sort of figure out some of the wire stuff but not all so a wire diagram would be nice.
it is also missing all the prop stuff I will have to locate this stuff
please add to this info or correct it
shift = green
blue
gen = yellow
blue
choke = red
main power large red and black
unknown wires
black/blue
white
brown
thanks in advance
tx1961whaler
Re: new to me evinrude with issues
skinny,
Private Message (PM) me with your email address, and I'll send you the factory schematic for that motor.
Added: sent! Good luck with the wiring.
skinny1965
can anyone send me a photo of the proper prop set up for this motor I have done a bit of looking and found one picture of different year but the prop I was given doesn't seem to attach the same way. the prop I have fits the shaft and has a hole in the end for the pin. then the cone (I need one) goes on.
skinny1965
thanks a ton those are way better than the ones I had before
