ctravis595
Thread starter- Joined
- May 10, 2013
- 50
I rebuilt the boat
It wasn't holding water but it was in need of restoration. The stringers were rotten and the transom was half rotten. I restored the transom with 4 layers of ply instead of 2 this time and spent a lot of time getting to know mr fiberglass, he's messy but stiff and reliable. I put her back in the water and I found my problem
The entire time I've owned this engine I somehow confused the positive and negative battery terminals even though the ground terminal clearly connects to the engine block. I'm a dummy
I wired the battery up correctly but have read incorrectly installing a battery will blow my rectifier and cause my engine to run on 3/4 cylinders. Explaining 99% of my issues thus far
Will report back after new rectifier
Thanks for the advice everyone. I feel much more secure on the water with my slight overpower on an old boat. My double cheeseburger transom should help. If I'm not happy with the 115 I might still install the bubble back since my engine already has the 140 carbs but I feel 115 on a 15 foot boat is plenty of power. The bubble back might improve my gas mileage however? I noticed that when I replaced my cars 5.0 v8 with a 5.5 v8
