strombolichef
- Joined
- Aug 28, 2007
- 91
OK, I have sold my boats with Seadrives, and Evinrude. So now I am at square one.
What I know
Boat is 84 chriscraft scorpion with driveshaft running under deck to outdrive (center engine). Boat is mostly sound, lots of work was done to it.
Outdrive is pre alpha, but seems to have alpha lower on it. Of course it has so much black paint, that there are no stickers or serial numbers visible anywhere.
Shifting is not quite right, not in sync.
Shift Bellows is gone.
Engine runs fine, no issue with that right now.
Water in outdrive oil but no metal shavings, oil was pretty dark, but milky as expected
Tilt works fine.
What I would like to know is how deep into this outdrive do I need to go, I know I better put in a water pump, but then which seals etc. to eliminate the water issue?
Also what basic tests should I do to make sure I will have a seaworthy drive before I take offshore? I will do the work myself, so will be making it a summer project (in florida thats like your winter project up north, too darn hot for fishing...)
I know there are many who have done the same thing many times over so will be glad to look at links to old posts that may help.
Thanks in advance for your assistance.
What I know
Tilt works fine.
