Previous Bayliner 21' inboard open bow owner. Just purchased a 2005 Apex Gillette 17' with Nissan 9.8 hp 4-stroke. Boat hasn't seen water since fall 2013 due to death of previous owner. Motor started a ran with muffs with no issues
Questions:
1) This small pontoon has gas tank & battery on rear platforms either side of outboard. When looking at other pontoons, we were told gas tank should be covered to keep water out of tank. Is that a valid concern?
2) Six gallon gas tank is about 3/4 full. Assume it is 2013 gas. The motor started right up with the muffs. Gas still smells like gas. Should we use it or replace it to be safe?
3) Do we need special pontoon fender bumpers or just the typical round ones. What size diameter and how many would you recommend?
4) It has a Bimini top, but it pretty thin. Don't know if it'll make it through the summer. Is it possible to buy just the cover and not the entire tube hardware? Couldn't find just a replacement cover.
5) Wife is thinking of sewing a new cover and reuse the zippers which are good. I think it's more work than it's worth. Anyone sew their own?
6) Previous owner threw away the boat cover because "it was too difficult to use". We've covered it with a tarp. We'll be storing indoors for winter. Any reason to buy a boat cover?
7) Purchase included a 54 thrust trolling motor. Never used one before. Other than fishing, can it used or should it be used getting into & away from the dock?
8) Brand new to pontoons. What key things do we need to know?
Questions:
