kssmallies
- Joined
- Aug 31, 2007
- 8
Hi, I purchased a new boat with a Mercury 500 50 hp motor. On the old motor registration paper it says 1971 but the local boat mechanic says it is a 1967 anyways I changed the lower unit oil it drained for about 2 days. I bought 1 quart of lower unit oil and when I changed it I squeezed from the bottom until it came out the top vent hole like it said to do. When I put the plugs back I noticed I barely used any of the new oil, I still had over 3/4 of the quart left. Is that normal or should I have used at least half of the quart? I also have a problem with going fast the boat goes like maybe 5 mph and thats it. When I throttle down the motor revs way up but I stay the same speed it dosn't go any faster and when I put it in reverse the prop spins but the boat barely moves back? Also when should I change the spark plugs? like every 2-3 months or like every 6 months? and is there any other maintence I can do to keep the motor going good ( change any other oils or grease anything, plugs or fittings to change) any thing like that? THanks any suggestions would help a ton.
