New to site with looking for help!!!
gms2010
Hello all, my name is Greg and I have bought a 1988 Four Winns Horizon with a 4.3 OMC w/cobra OD that was replaced about four summers ago. I am in search of a new distributor or used whatever is the most economical way of going about this. If anyone has some insight on the best way for me to get this done without spending a fortune please let me know. I am pretty "green" when it comes to marine engines, Thank you.
Don S
Re: New to site with looking for help!!!
Why are you looking for a new distributor? Is the old one missing?
Yes it is, thanks.
Ayuh,... I Gotta ask,... What happened to the original distributer,..??
I hear that Delco makes a nice marine replacement,...
Donno how they work with yer shifter though...
gms2010
This was a "handy mans" boat when I got it and been fixing it up and this was one of the things that needed replacement. When you say "work with my shifter" what are you talking about? Thanks for the help you all!
Greg
Howard Sterndrive
OMC used an electronic shift assist module (ESA) that "stumbles" the ignition to cause the engine to shudder (try to stall briefly) and allow the lower directional gears to disengage from the dog clutch when shifting to neutral (and the ESA also could do this going into gear, but that was less important).
Your 1988 4.3 would have had points ignition and your ESA module (if it is original and still there) is only compatible with points ignition systems.
If you end up going with Delco or other modern systems, you can modify the ESA system to work more like Mercruiser's "shift interrupt" system, or you can buy a new ESA from Rapair/CDI corp that will be compatible with most any 4.3 marine distributor you can find - points or electronic.. the CDI ESA is about $90 or so
Mercruiser style shift interrupt is a popular mod for OMC's but you lose the stumble into gear, as the Merc design only stumbles coming out of gear...which is fine.
gms2010
Thanks alot! I will start looking today and hopefully get one that does the job. The boat will be ready after this so I can't wait!
Joshua Nichols
Thats just a cap.. I think he is looking for the whole unit..
If I was you... I would replace with one of those elecronic Delco units.. They are kinda high and you will have to replace the ESA with the aftermarket unit that will work with it.. If money is a issue.. Buy a used one off flea bay.. People strip old trashed out engines and sell the parts all the time..
