New to the forum
Mario1975
Hi Everybody ! I just purchased this week an old Johnson 1966 6HP (CD-23E) that is clean ans starts with no more than 3 pullouts !!! It is in a very good condition and the previous owners took care of it. It come with a little 14' fishing boot with its trailer. The funny thing is that my grand father had one identical when I was younger (same year and model) so it remember me good stories from my childness.
Now the serious things ! I want to make the maintenance myself and I'm wondering if this model is exactly the same than the evinrude 1966 6HP (model 6602) with the same pieces number ? I found some "repair manual" on the net for the evinrude but since I have the johnson version, I'm not sure if I can buy it.
Thanks for your help and please, be leniant with my english, french is my native language.
Mario from Canada
HighTrim
Re: New to the forum
Bienvenue
J'esp?re que vous appr?cierez votre nouveau moteur. Il devrait fournir des ann?es de plaisir.
Excusez mon fran?ais, l'anglais est ma langue maternelle, mais je peux parler un peu.
Bonne chance
kenmyfam
Bienvenue
Bonne chance
Didn't know you spoke Welsh !!!:D:D
HighTrim
lol, I work with a Frog so have to keep up on my french to know when he is making fun of me or not. ;)
Mario1975
lol :D
thanks for these advices ! Your french is very good, it is not an easy language to learn as a second language.
Mario1975
Here is some pictures of the beast I took tonight ! :D
As you can see, it is in a nice and clean condition for its age.
I'll change the gear oil (I already did this operation in another motor) and check for the compression also. Is there a reason why you recommand me to change the water pump kit ? If it is not broken, why fix it ? Is it something that broke often and need to be replace frequently ?
Thanks a lot for you advices ! I don't have many messages yet in this forum but I already read a lot and learn many thing here ! Glad to found you !
bktheking
Ooof the ultimate insult to a french person, esti tabernac! (calling a french person a `frog`) at least here in Ottawa it is!
Replace the pump if it`s in an unknown condition, it`s the only cooling provided to the motor, no pump=siezed powerhead.
Mario1975
These aren't insult, they are the "F*** word" for french people so they can be use as a noun, verb, adverb, etc.... :D
bktheking
I know, I use them all the time, jai travaille 5 minute a gatineau quebec! Mon francais est mal aussi!
jgriner
when you dont know the history its a safe thing to do, I guess it should be changed every few years.
its reality cheap, and without a good one you will be quickly looking for a new motor
Mario1975
Thanks, I'll be safe and change the kit.
Mario1975
I did a compression test and both cylinder have 70 psi. Is it low for a 2 strokes motor ? Do I need to make a decarb with Seafoam ?
I did the compression test with the other spark plug in place. Is it the correct way to do this test ?
14ftgrumman
Both plugs out and grounded. 4 or 5 pulls. If within 10% of each other is good. Do the de-carb anyway, it won't hurt anything, and might get rid of insects.
HighTrim
He doesnt mind frog, but hates it when I call him crapaud (toad) ;)
Mario1975
:D
Do you know that Frog nickname for french canadian came from the WWII. They call us Frog since WWII for "FRench OriGin".
Mario1975
This afternoon, I did the compression test with a compression tester I borough to a shop of little motor like lawn mower and snow blower. It gaves me the 70psi on each cylinder.
This night, I bought a new compression tester and made the same test than this after noon. I remove only the spark plug of the cylinder I want to test. It gave me 90 psi on both cylinder. I did also another compression test but this time, I remove both spark plugs and it gave me also 90 psi on each cylinder so I don't think that removing all spark plugs will change the reading.
After that, I put the feet of the motor on water and start the motor. It runs smoothly. The water pump is working, I see the water exiting the hole on the middle of the feet.
I'm doing a Seafoam cleaning now. It will clean the motor and carburator and I'll test another time the compression after the seafoam.
Thanks all for your help, I appreciate your support (and your joke about my
FRench OriGin !!! :D:D:D)
