Lou C
- Joined
- Nov 10, 2002
- 13,978
While I initially viewed the issue of no-servicable gimble bearings and ujoints with disfavor, then I realized I have had jeeps for years with non serviceable front wheel bearings and u-joints. Over the years, the only thing driveline wise I have had to repair, is the front and rear CV joints on the front driveshaft on my '07 Jeep. Everything else is original at 127,000 miles.
On the '98, same thing, except nothing has needed to be replaced, at 181,000 miles!
So maybe it's not such a bad idea
For I/Os your main focus should be doing the yearly maintenance, it's easy to put off pulling the drive, everyone who's done it knows it can be easy to get off but can fight you getting it back on. I have been doing the yearly drive pull for 15+ years myself, with a drive jack it's easy and I have avoided a lot of repairs and down time doing this myself and the needed repairs that go along with it (bellows replacements, etc).
As far as grease I have been using Lucas Marine grease (blue stuff, calcium sulfonate base) and I feel it is very good. I use it in the gimble, ujoints and trailer wheel bearings. Driveshaft splines get Evinrude Triple Guard as does the prop shaft. Works for me in 100% salt water moorage and use.
