new trailer
dale1
greetings. today I purchased a 2004 24' seachaser walkaround with a magic tilt aluminium trailer with disk brakes, surge type.
the prior owner placed a block of wood in the hitch-slide to limit the amout of travel. he stated that he had to do that because the trailer would not back up. I removed the block of wood because I really need the additonal braking with the big pig. he was right. the trialer will not back up with the block removed. "but it stops good:)"
Ive never owned this type of trailer. any thoughts appreciated.
dale
Bob_VT
Re: new trailer
There should be a place for a lockout pin so you can back up. Very common with surge brakes.
not enuf toys
Re: new trailer
+1 on this
my trailer has a "pin" that i move into place to keep the slide from moving in. some have a bolt that you put in place.
i have been looking into a solenoid that goes after the master cylinder that reroutes the fluid back into the resivoir.
dale1
Re: new trailer
hey, what about the override switch. there is one on the trailer. I wonder if there is a way to check it, or is it just a change item? thanks, dale
NYBo
Re: new trailer
Do you have power to the solenoid/switch when the tow vehicle is in reverse?
