JSGOLD
- Joined
- Sep 22, 2009
- 609
Replacing the old clamp hand controlled type 65MX Minn Kota with a larger MK Edge55 foot controlled (cable) motor. This motor is quite different than older motor and much larger. Since it bolts down to the front of the boat rather than using a clamp I had a couple of questions...Does it have to be perfectly level? My old Starcraft has a coupe of raised areas around 3/8" and 1/4" in the area I need to use. Would not be off much but can cut and fit some starboard I have if that sounds better....Also If I install in the best location to get near centerline my motor will hit my winch on the trailer when I got to set for depth etc. Better to offset enough to clear that or just keep it close to center and adjust on the ramp as needed? Not sure if that is important but want to install as best as can.
I currently have one large battery that I bought last year and will add a second one later this spring. Was going to simply hook them together for more capacity and charge together etc. Would it be better to use a switch instead? All opinions welcome......
