onewhippedpuppy
Thread starter- Joined
- Jun 11, 2012
- 163
About a month ago I purchased a new (to me) 2004 Monterey 23', engine is a Merc 5.0 MPI with a Bravo 3 drive. Approximately 200 hours on it (freshwater), the previous owner replaced the impeller 3 years ago, idle control valve 2 years ago, did oil changes on both the drive and motor (last done in July 2013), and winterized yearly. That's it. He bought it from a friend's boat dealership and stated that they "went through it" before his purchase, but no receipts means it never happened. Before boating season I'm going to do preventative maintenance, with the goal being to cover everything that may/may not have been done over the last 9 years. So without further ado, here's my list:
Engine oil/filter change
Drive oil change
Impeller
Spark plugs
Fuel filters - inline and water separating canister
Check bellows and replace if they look dry/cracked
Lube gimbal bearing
Lube steering (not sure if there are zerks there or not)
Lube throttle shafts at motor
Lube prop shaft
Load check batteries (I believe 2 of 3 are bad)
Serpentine belt
Thermostat
Check bilge operation
Good thorough inspection - I've already found some sketchy stereo wiring that I want to remedy
Detail like crazy
Pray for hot weather
The boat runs great, I'd just like to insure that our summer is as trouble free as possible. Trailer is already sorted with an alignment, new bearings, and new tires. So, what am I missing?
Drive oil change
Impeller
Spark plugs
Lube gimbal bearing
Lube prop shaft
Serpentine belt
Thermostat
Detail like crazy
