I bought a boat (2002 20' Hydrasport)which was supposed to be in good working condition across the board. Not the case.
Trim tabs switches are reversed. Left is right and up is down.
Recently installed gauges said to be working do not.
After market guages-tach and fuel guage do not work. Volt seems to work as does temp in that they do register and stay in one place. Psi (whatever that is) has drops of water inside and I can't tell if it is working or not.
Though I didn't notice at the time there is no kill switch. Boat dash/controls recently refurbished for sale and apparently kill switch was left off. I did buy a lanyard though so if it weren't for absent switch I'd be good to go.
Since I have to take to Merc dealer for engine problems I will have kill switch installed.
I'm concerned though that guages may need to be replaced and because of extensive mess of wiring will cost me dearly for them to trace. It has to be done I suppose but I've discovered that guages are extremely expensive and wiring ain't easy.
Oh, yes there are no navigation lights on bow. More expense.
New fresh water pump not working. Fuse, maybe?
Any thoughts appreciated. Thanks
