new used(of course) 1956 12 hp johnson a few questions.
section8
hi. im Erik. i'm usually in the mercury part of the forum dealing with a pain in the ***** motor but i just bought this cool motor and had a question. it has a knob on the front and the guy who sold it to me said its the fuel air mix knob. it goes to the bottom of the carb. I turn it while running and nothing happens and the knob seems to turn continually non stop. any ideas? also wondering whats the fuel oil ratio. any ideas what it might need or any common things to do right off. he said he cleaned carb/new gaskets and changed impeller. i appreciate any help you can give me. THANX ALOT
BigB9000
Re: new used(of course) 1956 12 hp johnson a few questions.
it only has one knob?
weird mine has 2. (but mines a 10hp)
Anyway, its the low speed jet adjustment knob.
Put it in all the way, and back it out 1 1/2 turns. And your good.
Each time you turn it, it takes about 10 seconds to change anything (or so I have read) I have never noticed a difference no matter where it is. But thats just me.
Go read the top secret files. it'll answer most of your questions.
section8
it does have two knobs. i just noticed the top one cuz i took the cover off. it doesnt have a knob but it looks like a shaft that used to have a knob on it. whats that top one and what are these top secret files? thanks(i knew i would have more questions)!
Chinewalker
Let's start by figuring out what you've got as Johnson didn't have a 12hp in 1956 (or ever, for that matter). Model number?
section8
i was just looking for parts in the i boats parts and couldnt find any 12 hp parts so i was thinking, hmmmmmmm. maybe this aint a 12 horse. im gonna go look at it! well now.. the tab under the motorhead, on the front of the tronsom mount between the clamps reads" montgomery ward model #GG9016B serial # 65X609021" anyone have any idea about that?!?!?
section8
i just googled the model # and it came up sea king/monty ward. does this mean no parts for it. is this the adoptive sea king forum?
BigB9000
GALE MANUFACTURED PRODUCTS 1941-1963
GG-9016A 12 hp 1954-55
Its johnson/evinrude enough, most parts are the same.
tmcalavy
Your motor is a 56 Gale/Sea King 12 hp...reverse the first two numbers of the serial number to get the year. Good motors. Fuel mix ratio was 16:1 when new, but you can use 20 or 24:1 with todays TCW-3 marine oil. You have two rich/lean adjustments on the carb. Top one is the idle circuit (slow speed), bottom is the high speed circuit. Loosen the lock nuts on both up next to the carb so the knob/needle turns freely. Turn each one clockwise gently until it seats/stops. Back the bottom knob/needle out counterclockwise 3/4 of a turn. Back the top one out 1 and 1/2 half turns. Tighten the lock nuts so the knobs turn with some effort, but aren't loose. That'll get you started. After you get the motor started, adjust the high speed clockwise with the throttle up until it runs smoothly, then tighten the locknut. Throttle down and adjust the top knob/needle the same way...looking for smooth idle.
