Scott06
- Joined
- Apr 20, 2014
- 7,633
Yes you probably can reuse the gaskets yes put RTV on the rubber grommet for the bolts - basically use RTV anywhere where it could leak.Can I reuse my gaskets? I’m not from US and it take a while for me to import it from US. This Fel-Pros are quite new…
@Scott06 , RTV around head bolts you mean on the rubber grommet?
@alldodge , you mean to clean this oil galleys? Where are they? Do you have a picture ?
Last winter when changin oil I’ve used engine oil additive to flush the engine, I use it in my cars from time to time to keep engine clean. Now my oil is so fresh but maybe some gunk clogged it? Thanks for the response guys !
Hadn't thought of what dodge mentions you could have slow oil return to crank case and oil accumulates on top of heads at High rpm.
To test remove the valve covers and run at 3000 rpm... no seriously worth looking at if you have the covers off anyways
