Re: new way to change engine oil?
Guess it could be like my OMC where the dip stick tube is fit into the oil pan drain plug and nearly impossible to remove in the boat. On the other hand, since the dip stick tube has the suction hose fitting on it it makes the suction method get virtually all the oil. The problem I have is when I remove the filter it seems that no matter what I do I loose some oil into the bilge that I have to wipe up/ Seems to me the messy part of the job is the filter, not the dranining.
