I picked up a SR Seville 19 open bow fully knowing it would need full stringer replacement, but it had all the mechanicals just gone over, new bellows, runs nicely, so it was worth it for the outdrive and prop alone.
I've been reading a lot on stringer/floor replacement, and it occured to me that I have a bundle of .75 ipe (brazilian walnut) wood t&g flooring left over from the house. Probably 50 square feet. The stuff is like solid fiberglas. It takes some real work to glue it up, using resorcinol glue instead of epoxy, but there are long boards in the bundle, some over 5 feet. Sistering them may work.
The wood only slightly expands when wet, and is the densest heaviest and strongest I've ever worked with. I'm thinking it will make good stringer bases, at least, with maybe fir tongued in on top to make up teh depth.
Maybe it might even make a good deck, although I'd have to round over the edges to avoid potentially splintering corners. And the splinters are vicious.
Any thoughts on this material?
Thanks
MPergielWalkerMi
Thanks
MPergielWalkerMi
