Newbe question on Thermostats
IcantDo55
I have a 1995 3.0 LX that I just got and while going through it I find it has no thermostat in it??? It now runs fine (after replacing the rusted through freeze plug). <br /><br />Does it need a thermostat? I know on a car it holds the water in the rad long enough to cool off, but on an open system...would you need one?<br /><br />Thanks<br /><br />-Mike
natwales
Re: Newbe question on Thermostats
yes, you definitely want a thermostat, otherwise your engine will run too cool.
ron7000
Banned
with an open system which is also called raw water cooling because sea water is used to cool everything. An infinite supply of 80F or less water is constantly flowing through the engine, so it'll never warm up which is bad for combustion, fuel economy, power, and the oil.
IcantDo55
Got ya, thanks. What temp thermostat do you recomend?
No,.......<br /><br />Actually it holds the water in the Block to build Heat,.........<br /><br />The water in the Rad is what's Not being used, at the moment.............
