johnsaunders
Thread starter- Joined
- May 7, 2009
- 4
I'm buying a new 22' boat in a few weeks that I will keep in an assigned boat slip. I have several questions (some which may be stupid) and would really appreciate if someone could answer.
1. Do I need to connect just one spring line (that's 22') to the starboard midship cleat so it slides through then attach each end to the bow/stern cleats on the finger pier (fixed). The tides here fluctuate about 3-4'. Or do I need to attach one line from the stern pier horn to the midship and another line from the midship to the bow pier horn?
2. I have 3 strand twisted lines with loops/eyes in one end of each line. I am planning on keeping the lines on the pier with four additional lines kept on board. Should I just attach the eyes to the cleats on the boat or mix it up and put them on both the boat and the dock? What's the most secure way to attach the eyes? Or, should I just cut them off and tie hitches to both ends?
3. I'm confused about turning off the batteries when the boat's not in use and keeping the bilge running so rain water will be pumped out. Will the bilge still run with the battery setting turned off? If not, should I leave it on and/or plug in a power line to the dock?
4. As much as I'm looking forward to cruising around in a new boat, I'm nervous as hell about not tying up my boat properly and the lines being either too long or short for the tides. Any tips on how to know how much slack to give?
5. If I'm trolling with around 6 lines out and get a fish on, do the other lines need to be reeled in? Does the boat need to be stopped or should I keep trolling while pulling in a fish (when there are several other people on board)?
Any advice would be greatly appreciated.
