Newbie docking
Status
Not open for further replies.
lfunk11
Just got my first boat on Friday and have only had it out for about 25 minutes two times. Its docked at a marina and I am having some issues pulling the boat into the slip. Any tips or is just going to be something that I will take time to master. I have tried practicing out on the water trying to line up a buoy. I think its more nerves than anything - I don't want to smack into anyone's boat.
hivoltg
Re: Newbie docking
Nerves seem to play a big part in that. Having a person help to push you off anything sure helps too.
I like to keep a docking pole onboard. It sure helps pull or push you into place.
calvinator
Re: Newbie docking
Youtube has some good vids.
Look up "Jack Klang", he has some web pages with great information.
I have a 30' pontoon and only 16" between me and and my dock neighbor's boat. And the cross current is strong! It took 10-15 times before I felt confident.
Things I focus on when docking:
a) go slow
b) learn how your boat responds to reverse thrust and stopping.
c) dock into the wind/current so you stay under engine power and in control.
d) learn how to move the stern with reverse thrust and steering.
e) there should be no mad scrambles or people jumping off the boat onto the dock. Keep practicing until docking is a calm event.
f) a good training excercise is to get close to the dock, reverse thrust to stop, and then see how the wind/current affects your boat. Wind/current instantly moves my pontoon around, but my 21' runabout boat is less affected and stay put.
g) go to marina on a weekday morning when there is no one around and practice slow speed manuevers and docking -- a lot.
h) check into what a springline does
i) spend the time to get confident in docking. You'll enjoy the boat more. I have friends who only boat in perfect conditions when there are a lot of dockhands around b/c they fear docking.
j) go slow
lexer440
Re: Newbie docking
My neighbours used to run out to defend their boat when they saw me coming in to dock, now they just wave. Slow and easy, if you do hit another boat it will just be a nudge and you can throw a couple of fenders out. Practice, some advice from fellow boaters and you will dock like a pro in no time. Don't be afraid of making several attempts, we all have to learn and wind and current are not always friendly. There are also youtube videos from boat instructors that can be helpful.
greenbush future
Re: Newbie docking
Slower is almost always better, it's never good to come in hot, and sliding the throttle in and out of gear ensures you will go slow enough to recover from any docking maneuvers. Great idea about practicing a bit away from crowds, and the pressure they can create. We all learned at one point so you will get better with time. Having twin screws is always better, but none of my boats ever had them.
lfunk11
Re: Newbie docking
thanks - makes me feel a little better. There is an outdoor bar with people eating right near where I dock - that adds to the stress. I am going to get a docking pool - that would be helpful. I was also docking by myself last night - I would feel more comfortable if I had someone else on the boat to help grab the lines and such. The next thing will be getting the boat on a trailer at the end of the season :)
25thmustang
Re: Newbie docking
Ah welcome to boating! They don't teach you about the docking stresses we all face/faced. Slow works, but sometimes you need a little throttle. Practice builds confidence but even the saltiest skipper will have issues from time to time. Each time you dock will be a new adventure but know your boat, get your routine and keep at it!
JASinIL2006
Re: Newbie docking
All great advice. I would add that you should expect a few rocky dockings and don't get down on yourself. I know I provided my share of amusement/aggravation for other users of boat ramps as I learned how to launch and trailer my boat. Doing it with an audience only seems to make tougher, doesn't it? I've come to feel that anyone who doesn't have some sympathy for a beginner is a putz, so I don't worry about them anymore. Practice, read up and try techniques, and you'll be sliding into the slip in no time!
Natesms
Re: Newbie docking
Practice. Even though I've been boating my entire life when we first got our cruiser it was the same thing nerves + sticky shift cables = stressful and exciting docking.
We ended up giving the neighbors some beers and practiced docking in our slip with catchers along the side. We'd pull out of the slip, get the boat into a funny position and then force ourselves to recover and back it back in. Helped a ton for confidence. After a full summer with the boat I have no worries about docking anymore.
QC
Re: Newbie docking
Where do you boat? And what do you have? With that noted. My advice is to really understand the wind around your dock/marina. I have been on a few charters, ferries etc. and I always find my way to the Captain if I can. One of them, big boat, taught me something simple that can be helpful. Come to a stop well outside your slip and take a quick reading of what the wind is doing that minute.
Also, some have mentioned practice, but you should go out with your first mate. Just you two if there is a first mate. And do nothing but practice. Go out and practice backing in both directions. This way you will learn the particulars of your hull, and also develop a routine together. Also, watch others. Many times those that look like things are so easy are using simple tricks of the trade. Most often, with bigger boats, someone is using a line on a cleat that they use power to pull against and they can easily snuggle up to the dock. This is another thing you can do with a Boat Hook (docking pole). Use it to loop a line around a cleat, and then cleat her off on the boat side and use power as I mentioned. There are some good Youtube vids, and graphics on this technique as well.
Good luck and welcome aboard!!!
lfunk11
Re: Newbie docking
the boat is a little 19' bowrider and my boat is in Cheat Lake (WV). Last night I pulled into the marina and luckily there is a big gap between the individual docks running out into the water so I go down on the left side to turn into my slip on the right. I have a ton of room and I had it all lined up, but when I got closer things got a little off. I tried backing up and trying it again, but then the guy next to my slip came to his boat so I just decided to head back out of the marina and practice lining up the buoy. I am sure I provided to laughs for people or they thought I was drunk.
The slip has a rope running across the front with a clip that I attach to front of the boat and one on the side that clips to the back of the boat.
My parents are coming down for labor day weekend - looking to have fun, but the lake will be crazy if its nice so hopefully things go smoother. I appreciate all the help.
southkogs
Re: Newbie docking
Sounds like you're doing the right stuff: You're practicing and asking questions.
Pay attention to wind and water (currents, waves, depths, etc.) ... they all affect how you dock. Don't underestimate the value of light "bursts" of power OR the value of REVERSE. light corrections, and go slow.
As everyone else said ... practice & patience.
Home Cookin'
Re: Newbie docking
among the great suggestions here are to work against the wind/current, and to shift in and out of gear rather than try to idle slow in gear.
Since you are clipping on to lines already in place, you can have your own temporary short line, one end tied to your boat and the other with a clip, to clip on to the dock line on your approach, get the other parts squared away, then go back and hook up correctly.
If your boat is build with usuable rub rails, learn how to leverage the rails against a piling and pivot.
A steering knob is a great device.
You and your crew need to know how to cleat or wrap lines quickly; you can always go back and re-tie.
Even wuith experience things go awry. Just yesterday I got all jammed up at my pier--been docking there about 40 years and the last 5 with this boat and configuration.
Mason78
Re: Newbie docking
I find that I get a little better each season. Remember that no one is perfect, even seasoned boaters make an error occasionally.
crabby captain john
Re: Newbie docking
My marina often has 2 empty slips together -- even if they are only vacant as the owners are on the water. The dockmaster only needs to know you are practicing backing in and he will be happy you are taking the time to practice with only an imaginary boat beside you. Today I watched a newbie couple practice with the wind blowing the opposite direction of a strong tide change. They made it fun as there was nothing to hurt or hurt their boat.
aspeck
Re: Newbie docking
Keep practicing ... Especially turning one way and putting in reverse, then neutral, then turn the other way, then forward, and vice versa. This will help you understand how the boat will maneuver in close quarters. Also practice a slow glide, then reverse to get used to quick stops. These maneuvers will all help and be put to use in close quarters docking. Enjoy the process and practice. Also, if you know someone who does a great job of docking, ask them to show/teach you.
JoLin
Re: Newbie docking
Good advice in the posts above, so I'll just mention the first rule of docking... no matter how many times you've done it, there will always be an audience when you eff it up. The first time you come in perfectly, on the first pass, centered between the pilings... there will be nobody around to see it. :facepalm:
Though some may disagree, I never try to 'save' an approach that I think is going south on me. I bail out and come around again.
My .02
Watermann
Re: Newbie docking
Not sure how large your boat is but I have a video of me launching my restored 16' Sea Nymph, the principles are still the same. My wife thought I needed some baby bumpers but as you can see in the video she drifted right in and that was a mighty river with current. The momentum differs from boat to boat due to size but that's the key to mastering the docking process.
Oh yeah and you guys with hissing noise new trucks don't laugh at my old truck, it would most likely pull the chassis out from under your Toyota. :D
jbcurt00
Re: Newbie docking
Bump............. Howdy fello WV iboater............
How'd it go Labor Day w/ the folks?
Gotten the hang of navigating into the slip?
Pulled the boat for the season yet?
Status
