USMotorHead
- Joined
- Oct 15, 2012
- 52
Nice boat. I just replaced the transom on an I/O and it wasn't that bad. Replacing one on an outboard should be much easier.
Watermann... here in NY the prices and much higher.... lol.... 1/2 MP is $80 a sheet
You asked about plywood here, no need to start another topic just about plywood.
If you dont get enough info when you ask a question, quote yourself and give the question a bump.
What plywood (where in the boat) are you asking about?
1/2 for the deck (floor) is typical and OEM. Jumping to 5/8 doesnt mess up panel fitment along the gunwales or misalign the walk-thru windshield, too much but does take some effort to do. Using 3/4 usually requires adjustment for both.
Price MDO 4X8 sheets. Here they arent as expensive as MarinePly and are a great product to work w.
Aurauco is available at Menards if they are in NY.
As noted previously, by several, NO PT! Anywhere on an aluminum boat. No, I dont care that shops you arent using recommended PT. Perhaps they are getting commercially available PT. Thats NOT what you can buy at HD or Lowes and as of yet, anyone thats priced it online discovered shipping to be nearly as much as the price per sheet, so double the cost of MarinePly. But that is an entirely different type of PT that isnt available to 90% of us.
I'd use 3/4 MDO for the transom. Thats what I used in my Duracraft
I mark the holes and drill the transom out of the boat, that way you don't have to worry about the angle, just drill 90 degrees through.
