Newbie-mercruiser 3.0 question
ramairguy
Re: Newbie-mercruiser 3.0 question
Update again--I've taken the boat out 4 times now since the problem was fixed. I ran it real hard and have had no problems. Do you guys think this thing is in the clear now? The mechanic had said the test would be it's first few actual water rides.
tashasdaddy
it's mechanical, you are never in the clear. you are better off. keep up all the preventive maintenance. that will help keep you on the water.
My take on it is This,......<br /><br />You pumped the engine Nearly Dry of Oil,......<br /><br />You Dodged the Bullet,........ But,.............<br /><br />I'm SURE that Some sort of Damage Has Occurred,......<br /><br />How Much,........... Time will Tell.......<br /><br />IF this engine was to Run Great for Another 1000hrs,........<br />It WOULD have been Able to run More hours,.... IF What Happened,............... Didn't.............<br /><br />But there's No Way to Know For Sure,.......
jamesr1
Should he change the oil and look for shaving and such?
