Newbie needs help
achris
More fish than mountain goat
Re: Newbie needs help
First check out the owners handbook. All the info you need is in there.
newboater40759
the old owner lost the owners handbook so im pretty much going into this thing blind
achris
Sorry about that. I assumed when you said "new engine", you meant you had bought it new. One of my pet hates, people not reading the book!<br /><br />
  • <br />
  • Pre run check list<br />oil in tank under engine cowl<br />fuel in external tank<br />fuel line connected<br />engine tilted down<br />battery turned on<br />fuel primed (squeeze primer in fuel line until firm)<br />
<br />
  • <br />
  • starting<br />turn key to "ON" position<br />listen for beeps<br />push and hold key in and turn to "START" postion<br />as engine starts, release key and gently lift "fast idle" lever (the one at the back of the control box. Maintain about 1500 rpm<br />if engine starts to dies, push key in momentarily (this is the enricher system, the new version of a choke)<br />turn around and look at engine<br />check for water being discharged from the telltale on the right hand side of the engine (also check you don't have any flames coming from the engine (Just kidding))<br />as engine warms up lower fast idle lever<br /><br />now, go out and enjoy the day on the water.<br />
<br /><br />A new owners guide is available from Merc, and they're not expensive.<br /><br />Chris............
