I just accuired a 1995 40 hp mercury 2 stroke. It has a tiller handle with an run/off switch. In the piece the cowling clamps to is an engine tilt switch. <br />just forward of this switch is a hole which I assume is for the ignition switch. Do I need a switch with "push to choke" included as part of the switch and what is the wiring for the ingition switch? Also, does this engine incoporate the alarm for temp/oil pressure? If yes, where is the alarm? What type fuel fitting does the motor require? Is a primer bulb needed in the fuel line?<br />thanks in advance for the help. I have a manual on the way but I'm getting impatient.<br />Rob
