Newbie Needs Help
bryan372002
Just bought a used 25hp Johnson outboard, have no paperwork and cant seem to find the model or serial #'s, I did find one string of numbers on the transom bracket it is 319709-1 That is all I can find. I really just need to know right now what the gas/oil mix ratio should be, but also would like to be able to indentify this motor.
Thanks in advance for Your help:confused:
tashasdaddy
Re: Newbie Needs Help
look for a freeze plug on the engine block like this. if not post pictures of motor. oil mix depends on how old it is.
bryan372002
Thanks tashasdaddy I'll check for the freeze plug or post pics if that doesnt work.;)
bryan372002
Ok I looked on the freeze plug and the number there doesnt look right but what do i know...lol number is G2621483
I also took some pics as recommended and here they are, any help is greatly appreciated.
tashasdaddy
the "G" # is serial # those are not published. check with a dealer, the other numbers are part #s used on many different motors.
iwombat
The paint scheme on that motor puts it into the 80s at least. Which also means a solid 25 or so years into the 50:1 mix ratio.
In other words, mix 50:1.
