Hello all boaters out there, this is my first post...but, just to let you know I am a complete novice on this subject.
A couple of years ago I bought an boat on E-bay (by accident, never expected I would win it)
Luckily I used to have a friend living closeby knowing about stern drives, and he always used to help me out.
Since he moved, my boat has been idle with a impeller change job half finished....so I am a bit stuck.
Anyway...with Summer on the way I decided to do it myself and learn the job as I go, hope you guys (any ladies?) can help me out a bit.
I also would like to do maintenance to vital parts (once I found out what they are and how to do it)
The boat is pretty old and driven by a Mercruiser Alpha one stern drive gen I , driven by a 3.0 lit MCM engine.
The lower leg is off and the upper section still connected to the boat.
Impeller, and gaskets are bought and ready to install but first I would like to understand the mechanics of the drive a bit.
My first question (probably of many more to come) is this:
The propeller is completely locked, it does not go forward or backward.
What exactly is going on? (I noticed the lower leg was taken off whilst throttle was in neutral)
The main shaft can be turned freely in both directions by hand easily, but propeller does not respond.
I tried turning the shift shaft into forward or backward but even with a plier I cant get it into gear.
I am afraid I might damage the teeth or worse inside, so question is is this normal and could somebody explain?
