davemoore
Thread starter- Joined
- Jul 7, 2009
- 96
Newbie here... these may be dumb questions, but how else do I learn?
Boat: 1983 - 18' Marlin with Mercruiser I/O...
#1: What is the rule of thumb about running the motor with the outdrive up (trailer position)? Should it NEVER be done? I noticed that when I had it running with the unit up, at about 1500 RPM there was a really loud "rattling" noise in the upper unit, but when it's down, it wasn't there. Of course, I had the control in neutral. With the drive down, no matter what RPM's (800 - 4000), the outdrive is quiet.
#2: While in the water, how many degrees does the outdrive move when you trim up? I assume all the way down is 0 degrees. I don't know the answer to this because my trim switch doesn't work, but from what I've read it seems like it's FAR less than when you "trailer" the outdrive.
Thanks,
Dave
Thanks,
Dave
