Newbie with Questions - Suzuki DT115
benkitto
Hi All
Im a newbie having just bought a fletcher 17ft ski boat with the following:-
Suzuki DT115 Outboard
Suzuki NA12S Control Unit
We are doing some work on the boat and need some advice an guidance if you dont mind!:)
1. What is the rev limit on this engine?
2. is there a manual on the engine anywhere to download?
3. The Tachometer in the boat has never worked - have removed it today and the wiring behind it has been cut. What wires do I need to connect up to make the new Tach I have bought work?
4. I'm replacing the mechanical cable steering - the engine is in situ on the boat and there is not enough room to remove the ram from the outboard housing as the cable willl not bend enough - thinking about loosening the outboard and sliding it along the transom to allow it come out - is this a good idea?
Thank you in advance for any replies - again - apologies im new to this and really finding my way in the dark:redface:
