bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
I just picked up a newer Johnson 2 cylinder with no ID on it and it's been painted over in camo. Sorry guys but I hate it when people do that. The PO stated he thought it was a 1989 35hp but nothing there is adding up correctly. I believe it's newer. It also doesn't have the stamped ID tag or the rivet studs where it should have been. Looks like it had the newer printed label on it which is also gone..
I started a search thru PRB site, going through the years and models. The closest match I can find on the carb is a 1995 35hp. The Engine cowl is also one that has the same shape as the Evinrude, not the more squared off one. The exhaust section also matches the mid to late 90's as does the lower unit with the anode in it above the prop.
Was going to post some pictures with this but the camera battery died! As soon as it's charged I'll post some. So if anyone has any clues or leads I'd really appreciate it.
