So, I took out my newly rebuilt 55hp (3 cyl) for the first time yesterday. At first it seemed to run OK, though somewhat rough at low speeds. At WOT it run quite nice (only ran it there for a bit due to beinga new rebuild). Then after 30 min, it essentially lost a cylinder and began missing.
I called the shop and they suggested putting another set of plugs in as they could have fouled due to running 25:1 for the break-in period (Im running XD 50). I put in a new set of plugs, and it ran OK again, for about 20 minutes; and then the plugs fouled again.
The shop says something is wrong and to bring it in. Any ideas on what might be wrong?
I checked the choke linkage, and it seems to be fine, with the butterflies open with the choke set to auto or off. The shop had set the low speed needles in the test tank. Is there any chance these could be off enough to cause this condition?
Thanks alot.
Thanks alot.
