CaneCutter79
- Joined
- May 24, 2009
- 454
Re: Next hotter plug from QL77JC4?
Here are photos of the thermostat assembly after I removed it. This is how it's installed (location of springs, orientation of springs, relief valves, stats, etc.)
These are new spark plugs that have about 2miles of use on them. I decarbed the motor (using the sticky at the top of this forum) and replaced the plugs with brand new fresh out of the package plugs. This is what they look like (probably leading to an entirely different issue but posting pics here just to help with the motor running cooler than recommended issue)
Plugs from cylinders 1 & 2 with cyl. no. 1 being on the right. (as if you're looking at the motor behind the boat)
Plugs from cylinders 3 & 4 with cyl no. 3 being on the right. (as if you're looking at the motor behind the boat)
All spark plugs in order as if you're looking at the motor (cyl. no. 1 in upper right, no. 2 in upper left, no. 3 in lower right, no. 4 in lower left)
Thermostat assembly with housing
